Rigid forks and big...
[Closed] Rigid forks and big rotors...
[#3161551]
I'm thinking of getting a pair of rigid forks for my Ti Voodoo to use when the Thors are off being serviced, or for road-use.
I can easily switch the ProII back to QR, but I don't want to faff with brake rotors. Are there any forks that will cope with a 200mm disc rotor?
I reckon I'll need to get a 29er fork (465mm ish A2C) as the frame is designed for 130mm forks, and isn't too slack at that length.
Posted : 19/09/2011 10:34 am
there doesnt appear to be a rotor limit on the on-one forks, but you can always email to check.
Posted : 19/09/2011 10:38 am
Surly Instigator forks are rated for tandem use, which [i]implies[/i] they'll take big discs, though it doesn't seem to be stated anywhere. Bet they're heavy.
Andy
Posted : 19/09/2011 10:48 am
Thanks.
emailed On-One and Surly.
The Surlys are 3.13lb apparently. Not much of a weight saving over the Thors!
Posted : 19/09/2011 11:44 am
200mm rotor + QR? No thanks!
Seen the qr pop out many times by people braking too hard...
Posted : 19/09/2011 11:47 am
ok, how about a bolt-thru rigid fork? 😉
Posted : 19/09/2011 12:00 pm
xiphon - Member
Really?! Sounds like some serious mechanical numptiness if you've really seen that commonly as I've never seen it.
Posted : 19/09/2011 12:06 pm
ooh...
Salsa Cromoto Grande with 20mm maxle...
Posted : 19/09/2011 12:14 pm
I briefly used a pair of 445mm Cromoto's on mine - I really wouldn't have wanted a taller fork.
I had mine set up with a 160mm rotor but have used them with a 180mm rotor on another bike.
Very comfortable ride - a noticeable amount of (good) flex is felt.
I would have thought a 200mm disc to be okay.
Here is mine (just after being built) now with Rebas at 100mm and gears 😆
IIRC mine weighed about 1020g with the steerer cut to about 235mm
Posted : 19/09/2011 12:23 pm
Those CroMoto Grandes look good; don't think the Maxle version's actually available yet though.I'd also suspect they won't be making a 26" version seeing as they've stopped making 26ers (Mukluk aside) for 2012. There's always the X-Lite carbon fork with 15mm TA.
There's lots of the physics behind this [url= http://www.ne.jp/asahi/julesandjames/home/disk_and_quick_release/ ]here[/url]. If memory serves, this is one of the reasons Cotic put the Roadrat front brake on the 'wrong' side.
Andy
Posted : 19/09/2011 1:06 pm
and what exactly do you think the change in position of a calliper for a 200mm rotor does to the force component in the direction of the drop out opening compared to a 160mm centred calliper ......?
Posted : 19/09/2011 1:35 pm
