Rigid fork advice
[Closed] Rigid fork advice
 ss
[#2160205]
I'm struggling to find a pair of rigid forks with the following attributes
- To suit 26" MTB wheel with standard QR
- Steel
- Capable of relatively technical off road riding
- Adjusted for 100mm suspension frame (about 460-470mm axle to crown?)
- Mudguard mounts
- Disc and hopefully v brake mounts
Does anyone know of such a fork? And better still, does anyone have one for sale?
Posted : 05/11/2010 2:15 pm
http://www.on-one.co.uk/i/q/FOOOCR26DV/on-one-cromo-26er-mtb-fork-v-brake--disc
No mudguard mounts, but as good as you're going to get.
Posted : 05/11/2010 2:33 pm
I dont think a 100mm corrected frame needs this length of fork.
Original MTB forks are 400mm, Im pretty sure your'll only need 440mm max.
420mm if you want quick steering.
Posted : 05/11/2010 2:46 pm
440mm is 'standard' - equivalent to a sagged 100mm fork.
Posted : 05/11/2010 2:47 pm
If you really want a really tall one, pipedream made a proper tall rigid fork. Or the new breed of 29er fork.
Mudguards can be p-clipped.
Posted : 05/11/2010 2:51 pm
Goknock yourself out - http://www.viciouscycles.com/forks.php3
Posted : 05/11/2010 3:00 pm
Are knifen forks still available from planetx?
Posted : 05/11/2010 3:30 pm
 ss
Ok cheers, I think Kona P2's come in 440mm length, hard to find them in stock at the moment though.
Mudguard mounts are a must as it'll be mainly commuting for the next few months.
Thanks for the help.
Posted : 05/11/2010 3:43 pm
 PJay
As others have said, 440mm is about equivalent of 100mm fork with sag. I run a 450mm rigid on mine (recommended by Pipedream, the manufacturers of my frame) on a Pipedream Sirius frame designed for 90-130mm forks. Pipedream make their own [url=
fork[/url] but I'm running an [url= http://www.orangebikes.co.uk/components/#components ]Orange F8[/url], which is a great fork. Both the Infinity and F8 are disc only I think and I'm pretty sure that the F8 has mudguard mounts.
Posted : 05/11/2010 3:49 pm
My Salsa Cromoto's got threaded eyes for fenders... I've got 425 but they do 445 as well which should be plenty long enough in a 26er.
Great fork.
http://salsacycles.com/components/cromoto_26/
Posted : 05/11/2010 3:51 pm
+1 for salsa cro-motos.
got a few thousand off road miles on a pair and can't fault them.
Posted : 05/11/2010 4:08 pm
Keep your eyes open for P2's. They do pop up every now and again in the classifieds and are worth the wait. My V-brake set have mudguard mounts.
Posted : 05/11/2010 4:09 pm
This seems to fit your original spec dont really now how you missed it
[url= http://www.wiggle.co.uk/surly-karate-monkey-29er-rigid-fork/?referid=frogoog&source=googleps ]The link[/url]
You can see it has mudguard tabs by the dropouts
seems too long to me though
Posted : 05/11/2010 4:48 pm
