That's the whole point of Hopes IMO :wink:. You can "feather" them, a slight squeeze means very little actual braking, but the harder you pull the more you stop!
right, got the E4's ...now to trim the hilariously long hose without p*ssing brake fluid everywhere. Is it possible to do without a bleed?
Bleeding Hopes is easy, always bleed from new (the dot fluid might be pretty old....you don't know how long they've been sitting around for in a warehouse) or when you cut the hoses.
I've always used Hope 4 pot on tandems, two sets roughly 15 years old. It's possible to overheat them but overall I've been very pleased with them - excellent power and modulation.
In fact one brake from each pair has failed (conveniently, one front and one rear so I still have one workng pair) so I'm about to buy another set. I'm not disappointed with their longevity, they have had a fairly hard life with little maintenance.
I've had mono mini's, X2's, XTR (older), XT (newer) and Avid Elixirs (various versions).
The hopes I was running with 140/160mm rotors even though I weigh 100kg. They were barely an imporvement on V-brakes but that's all I wanted. Ditto the X2's.
XT are great if a little grabby, not much more outright power than the Avids though, it just comes in one big hit.
The Avid's are fine when they work, but getting them bled properly can be a PITA. I'd accept new ones on a bike, on the basis I could keep returning them untill they worked! But I'd not get them aftermarket.
I'd save all that money the Hope's cost and get shimano, they're just better.
Although at the moment I'm starting to want some even stronger brakes on the fat bike. You can hit corners at frankly terifying speeds which them means you're not going the speed the trail designer intended you to be going and sudenly need a lot of braking power from those 180/160 disks, and with 4" tyres even a 160mm rear disk is capable of doing alot of braking! Heck even on a normal bit of trail the grip allows you to brake after the last braking bump without losing traction!
If you want bling brakes, get Clegg's, they make Hope look like they fell out of a cracker.
LOL, they look awful.
So you've moved up to disk sizes that offer 20 percent more power front and rear and your comparing power?
The Race X2's my old man runs are easily as powerful as my Deore set, except they modulate a bit better and weigh a good deal less.
