[Closed] Reverbs
[#4957239]
I'm in the market for a reverb and was hoping somebody could help me tell the difference between these two (other than a years release and £100)
http://www.chainreactioncycles.com/Models.aspx?ModelID=84856&gclid=CJO76qGL-rUCFZDKtAodSg0A7Q
and
http://www.chainreactioncycles.com/Models.aspx?ModelID=66878
The weight the spec seem to be almost identical. Am i missing something?
Posted : 13/03/2013 5:20 pm
Ones a 2012 model ones 2013
Posted : 13/03/2013 5:21 pm
100mm drop on the cheaper one, 125mm on the other too.
Posted : 13/03/2013 5:23 pm
One has no bleed kit and probably a few other clips and things that come in the box - basically it's an OEM post.
Also, the 2011 posts had some reliability problems, which were solved for 2012 - most (not all) 2012s has a black collar. The 2012 pictured there has the silver collar, but that doesn't necessarily mean it's 2011.
I see, so the main differences are the drop (100m vs. 125mm) and some reliabilty on the older model.
Neither come with fluid and the bleed kit.
Think I might take a punt on the cheaper one.
Thanks,
Posted : 13/03/2013 5:32 pm
in fact just checked - the cheaper one also has 125mm drop. I'm none the wiser!
Posted : 13/03/2013 5:33 pm
2 descriptions one says 100mm other says 125mm ?
Posted : 13/03/2013 5:49 pm
so why not just buy the cheaper one?
you can always send it back for free if it's not 125mm drop. Nothing lost 🙂
Posted : 13/03/2013 6:04 pm
Different hose strain collar on the older one where the hose enters the top of the post - newer one is less likely to snap of the hose barb fitting if you snag it in a crash. I did that to the older one, and it's very easy to replace with the newer part and then you effectively have a new post. You do need the bleed kit to fit it though. I also think there was a few people who had air leakage problems on early ones - but I had no issues with mine. I've got a newer one, and said old one, and can't tell the difference in operation.
Posted : 13/03/2013 6:11 pm
I rang up CRC, it is the 100mm one.
MMMMmmmmmmmmmm.....really want one, but no point settling so might hold out for the 125mm.
(there's one on ebay for 120mm - which I didn't think even existed)
Posted : 13/03/2013 6:21 pm
