Reverb Under Saddle...
[Closed] Reverb Under Saddle Lever
[#7160994]
Has anyone bodged a Reverb to work with an under the saddle lever?
I have a couple of bikes that I want to be able to move the seatpost around on, and dont want to have to disconnect a remote every time.
Posted : 29/06/2015 10:47 am
Just buy a cheap KS supernatural with a lever. My old one was bulletproof and was designed for that
Posted : 29/06/2015 10:48 am
I rode a KS with a lever for about 4 years, replaced with a LEV and bar mount which I've had for nearly 2 years. I tried to go back on the XC bike and no way I was taking my hand off the bars for the crotch grab drop. Under saddle adjustment is a backwards step. If you want to swap it something like a lev and 2 lever kits would work.
Posted : 29/06/2015 10:51 am
Would go for a Thomson if I could get hold of the under saddle lever.
Posted : 29/06/2015 11:09 am
I know what you mean about it being backwards, but this is to swap between 2 XC bikes and a fat bike.
Posted : 29/06/2015 11:11 am
Have you tried both options? Seriously being able to swap isn't worth the bad idea of the under the saddle lever. Lev does give you the simplest swap though.
Posted : 29/06/2015 11:12 am
Yeah I already have both, much prefer the remote on the Enduro bike.
Posted : 29/06/2015 11:39 am
I've always run reverb under the bar,feel they are better that way. Had a reverb since they first came out, and run them on 3 different bikes,currently running stealth one under bar on my bronco, never had an issue. Buy a right hand remote and mount it on left of your bar if you running 10th or 1x11
Posted : 29/06/2015 2:19 pm
Why, it's one bolt, 30 seconds to get take it off, 30 seconds to put it back on?
Posted : 29/06/2015 5:14 pm
I'm sure a handle bar lever is better.. but I went cheap a couple of years ago and bought x-fusion with crotch grab lever. Sure have to pick my moment to use it, but its perfectly fine. If money/less hassle is what you're after then don't discount the idea. Only time i'd say it was actually dangerous is if you're racing...
Posted : 29/06/2015 5:45 pm
mildbore - Member
Someone didn't read the OP properly 🙄
Posted : 29/06/2015 7:00 pm
 br
[i]I'm sure a handle bar lever is better.. but I went cheap a couple of years ago and bought x-fusion with crotch grab lever. Sure have to pick my moment to use it, but its perfectly fine. If money/less hassle is what you're after then don't discount the idea. [/i]
This. I've one on my XC bike and tbh just didn't put the cable on as I want to be able to just swap to a normal seatpost when required.
Posted : 30/06/2015 12:33 pm
