Last 10 mins of ride yesterday and on a techy bit,Dropped the seat and that was it: stuck down. Any ideas; is it an LBS thing?
Mine has done the same taking it to the shop today,it is one of the very first ones, this will be the 2nd time in about 5 years its gone wrong so pretty damn good only serviced once, due to it just working fine 😀
Tried pumping the lever or, failing that, a bleed ?
Maybe just needs the release lever hose bleeding? Pretty simple job.
Cheers guys....LBS it is then as I have very little gear and am crap
Did it come with a bleed kit (bottle of fluid and syringe)? If so, that's pretty much all you need and it really is a 5 minute job - look on YouTube for how-to videos.
Due to the encouragement and "5 minute job" quotes I did as advised: no babies died; no third world countries were wiped off the map; and I now have a working reverb. (Loads of air in it ???)
Many thanks people
