Just ordered myself a stealth and was wondering if it will come with a barb connector or if i will need to purchase one separately?
Anyone bought one and know the answer?
The new ones come with the connectormijig, you should get a double ended thing to help route the cable through the frame holes as it's easier to disconnect the pushlock end
Thanks philfive.
Presumably i will need to find some hose to help with the routing?
yeah you just need a length of brake outer to pull the hose through with.
youtube has some vids of the method. It's straightforward.
I have seen the videos - looks fairly straight forward. I just wasn't sure what was and what wasn't included in the box.
Gear cable will work too, that's what I used
