Reverb Stealth Fitt...
[Closed] Reverb Stealth Fitting
[#10167400]
Morning All,
After a battle I’ve decided my old reverb stealth is dead, and I’ve bought a new one (old one was out of warranty and never really worked great anyway).
Watching the SRAM videos and reading some forums, I’ve a few questions I’m hoping you might be able to help with.
How critical is it to use the crowsfoot on the torque wrench if you’re re-connecting the connectamajig? Cheapest I can find in nearly £30 for a one use tool. I’m fitting it to a Whyte T-130 and the frame holes are tight so it may come down to unthreading the remote if the connectamajig doesn’t fit through.
Lastly, what’s the best/cleanest technique for cutting the hydraulic cable when you trim it? The SRAM video shows some bespoke tool but anyone have any other ideas? Stanley knife? Scissors?
Thanks in advance,
M
Posted : 14/08/2018 10:09 am
Not stealth but when cutting the hose on my externally routed reverb I just used normal outer cable cutters. The end gets a little crushed, but it doesn’t hamper the insertion of the button barb. So works well.
Posted : 14/08/2018 11:33 am
 5lab
as above, and i just nipped the connection thing up 'pretty tight', there's no fluid coming out so I figured its ok
Posted : 14/08/2018 11:40 am
I bought the hose cutting tool for less than a tenner off ebay.
Did not bother with a torque wrench to re-connect the connectamajig and all seems fine.
Posted : 14/08/2018 12:26 pm
Cheers for the answers and tips guys. Decided to remove the remote and use the red twin-barb to thread the hydraulic cable back through. Figured if I’m going to have to trim it anyway I might as well not bother using the connectamajig. Bought a cable cutter from a DIY place so hoping for a clean cut.
Posted : 15/08/2018 10:22 am
Success! New post fitted and working like a dream, without needing a bleed!
Posted : 18/08/2018 12:08 pm
Connectamajig has always appeared pointless to me since it won't fit through any frame I own. Think it's only purpose is so you can remove your post and send it off for warranty (which I've never had to do)
Posted : 18/08/2018 1:56 pm
