Reverb Stealth fitt...
[Closed] Reverb Stealth fitting Q
[#9973507]
I have a Whyte 909 and want to swap its OE dropper for a Reverb. Is the best way to connect the RS barb connector to the old hose and the new one, and pull them both through the frame? Then give the Reverb a full bleed?
Posted : 05/05/2018 8:58 am
Seems a sensible way to do it. Although when I've fitted a stealth post in the past I've always found the hole in the frame easily enough due to their size. Your way will work fine.
Posted : 05/05/2018 9:14 am
I assume its not a connectamajig version? If it is just push it through the frame.
Posted : 05/05/2018 9:24 am
I will order the connectamajig version but the routing is 100% internal through the downtube and seatube. There's no opening between the two. So I'll have to route the new hose connected to the old cable, I'm assuming.
Posted : 05/05/2018 9:33 am
Yeah if its full internal it would be best to join and bleed.
Posted : 05/05/2018 9:34 am
Do the RS barb connectors screw into a standard outer cable ok? Guess they're designed for Reverb hydraulic hose but it looks like it'll bite into the plastic inner sheath of a standard outer.
Posted : 05/05/2018 9:37 am
