Reverb Stealth -3rd...
[Closed] Reverb Stealth -3rd bleed and getting fed-up now!
[#8467115]
Rebuilt my Reverb Stealth and bleeding it is taking a while....on the 3rd bleed (full bleed process following SRAM instructions) and now the post at least compresses/rises on min. rebound (but not on max. rebound) - any tips?
Posted : 24/04/2017 9:10 am
Another bleed? Checked for leaks? Did you bleed with minimum return on the adjuster at the bar?
Posted : 24/04/2017 9:30 am
No apparent leaks and yes, I guess I'll try another full bleed.
Posted : 24/04/2017 10:03 am
I had / have this with a stealth. Spent what seemed like hours, bleeding, rebleeding, starting again etc. - gave up. Did the same thing a few days later but still wouldn't activate when the adjuster is all the way out. I just leave it screwed in and it works fine.
The only thing I could think was that I've messed about and swapped levers between 1st generation and 2nd gen models and between stealth versions and external routing versions - think I've had 4 or five going between different bikes at various times - I figured there was no difference but perhaps there's a slight volume change somewhere along the way.
Posted : 24/04/2017 10:25 am
