How often do you do it and what do you do?
I've had a few KS droppers and just used to remove the inner post from the outer post every six months or so.
Had a Reverb for a few months now and wandering if it needs the same kind of attention?
Leave it until it needs something doing to it. Mine lasted a good 2 years before needing a service. Unfortunately rather than splashing out on a proper full service I spend £40 on a quick clean and rebuild which lasted about 5 rides so now needs a proper full service. So use it until it needs a service and give it a proper full service.
Actually self servicing looks possible. A big task but not requiring any particular skills, just a methodical approach to ensure you cover all the correct steps in the correct order. I'll give it a go myself next time. The cost of a full service kit is about £40 I think.
That sounds reasonable.
I might look into that.
