Reverb self service
[Closed] Reverb self service
[#6360386]
As one or two of ya know I've had a few issues with my reverb,so I decided to bite the bullit & order a service kit !.
So today after watchin a clip on YouTube I stripped it and replaced the seals,rebuilt it,blew it up to 250psi,& guess what ???....
It works!, I'm well pleased with myself as I've saved both time and money ,best £7 I've spent in a while ..
Posted : 23/07/2014 7:17 pm
Wanna post a link to the clip?
Posted : 23/07/2014 9:45 pm
Here's the link on youtube !,
http://m.youtube.com/watch?v=XxgUK3gC_Fk
Posted : 23/07/2014 9:48 pm
What were you're issues? Mines alittle notchy at the moment and drops slightly, thinking service is needed but lbs thinks it may need new cartridge and to be sent off to Sram
Posted : 23/07/2014 9:56 pm
Where for the service kit?
If it drops when you sit on it, send it back. Chances are they'll replace with new.
Posted : 23/07/2014 9:58 pm
Cheers reedspeed 🙂
Look at this on eBay:
ROCK SHOX REVERB SERVICE KIT FOR POST (BASIC) SEALS O-RINGS
261496568577
Posted : 23/07/2014 10:07 pm
It was dropping it's fine again now !,a reckon I've saved about £40 in the process ..
Posted : 23/07/2014 10:08 pm
Done the same a few times using that video. All 3 times it has only needed a 2 pence O ring. The second time I did it I used the £7 service kit but the same O ring failed after a couple of months. Every time the O-ring failed it happened just after the big silver locking collar on the post came loose. My friend has had exact same issue and same seal failure as a result. I have now loctited the collar and so far it has been fine and no more seal issues.
Posted : 23/07/2014 11:08 pm
I'd actually like to know which O ring it was/is too,as the thing is I've replaced em all & probably didn't need to .
Which issit that fails ?,& funnily enough my collar has been loose.
Posted : 24/07/2014 8:01 am
