Reverb Sagging 5-10...
[Closed] Reverb Sagging 5-10mm...Solution?
[#7230532]
Had my Reverb for 18/24 months now, always been perfect, noticed that it's started to sag by about 5-10mm lately...what needs to be done? Bleed? Service?
Advise welcome...
Posted : 31/07/2015 8:16 pm
Mine went back to TFT for this = minute scratch on damper rod thingy = £45 for part and repaired under warantee.
Posted : 31/07/2015 8:26 pm
Send it back for warranty and usually they just send out a new one because it is too time-consuming to repair every reverb that is sent back.
Posted : 31/07/2015 9:29 pm
I brought it from Rose Bike in Germany, do I send it there or elsewhere? Guessing I need I make contact first?
Posted : 31/07/2015 10:50 pm
Needs an internal bleed most likely. It is home doable but it's a faff. Guide on SRAM YouTube if you fancy it! If it's done a couple of years then itll need a service anyway
Posted : 31/07/2015 11:05 pm
It's a common problem - mine was replaced under warranty by bike-discount.de.
Posted : 01/08/2015 5:16 am
 ichi
Yup warranty job. Mine was replaced by bike discount. Send it back to Rose, it's a well known problem.
Posted : 01/08/2015 6:15 am
Warranty, after 18-24 months of otherwise perfect function with no service in that time?
Surprises me that they will honour it tbh.
My wife's is well overdue a full service at 2 years old with just a couple of bleed/fluid changes and a pressure check or two. It's started to develop a little play and is harder to compress but I never thought of trying to warranty it, just thought that length of time was a pretty good lifespan for that sort of component given its relative complexity.
Posted : 01/08/2015 6:37 am
Most people seem to know this already, but if your Reverb has any vertical play it's a warranty job. I just took mine back and got a new one sent back within 5 days. Given that they have a 2 year warranty I would not think this would depend on it having a service in that time.
Posted : 08/08/2015 10:30 am
And no need to send back to Germany.
I got mine from alltricks but jejames dealt with it. Just needed proof of purchase.
Posted : 08/08/2015 10:36 am
Yes with proof of purchase you can return it you any shop that deals with them ie your LBS.
Posted : 08/08/2015 10:41 am
