My reverb post is sagging or sinking about an inch when fully extended and you weight the saddle but aren't pushing the remote. Anybody know if it his is a symptom of the system needing a bleed or should I send in under warranty?
Posted : 16/10/2012 11:07 pm
Mine did this and a full bleed didn't fix it so sent it off to tf for a service. Turned out it was a bit shafted so was done under warranty, but bleed first then service if that doesn't fix it.
Posted : 16/10/2012 11:14 pm
Needs a bleed.
Posted : 16/10/2012 11:38 pm
Thanks. Ok so looks like I need to bleed and then assess from there.
Posted : 17/10/2012 1:37 pm
Mine did the same and had to go back under warranty for new internals
Posted : 17/10/2012 1:52 pm
Carried out a bleed and not resolved the issue so guess it's off to Fishers for some warranty work
Posted : 20/10/2012 3:41 pm
