Hi.
I am just about to purchase an Reverb B1 which has the MMX bar clamp.
Having looked on line at old threads it says you also receive a clamp to run it with a standard bar mount? Is this correct or is it just MMX set up only?
Thanks
Posted : 07/03/2017 8:55 pm
The MMX mount doubles as a standard bar mount so you will be fine.
Posted : 07/03/2017 9:40 pm
as above the MMX has extra bits for the shifter you can ignore, but it doesnt have the spacer. On an alu bar or if you're attaching to SRAM brakes then don't sweat it. If its a carbon bar is going on, and standalone you might want to source one.
Posted : 07/03/2017 9:55 pm
It would just be going on standard alu bars, I just need the standard bar mount as my brakes are XT M8000.
Thanks
Posted : 07/03/2017 10:09 pm
