Reverb MMX clamp
[Closed] Reverb MMX clamp
[#4177376]
does this fit the regular matchmaker clamp?
i.e. ive got Sram XO & avid elixir CR brakes on a matchmaker clamp, can i incoporate all that on an MMX clamp? or would i need the other version with its own clamp? does it come with both?
Posted : 19/07/2012 2:28 pm
This is how it works... so I think the answer is no.
Posted : 19/07/2012 2:36 pm
So is it available in a regular clamp or does it come with one?
bike discount, CRC, wiggle all seem to have MMX only?
Posted : 19/07/2012 2:46 pm
The MMX clamp works as a clamp on it's own, it doesn't need anything else. I run the RHS MMX upside down on the LHS and it works perfectly 😀
Posted : 19/07/2012 3:13 pm
The MMX bit bolts on to the remote clamp and allows you to mount sram shifters to it, the mmx bit is a separate part in reality to the bar clamp. The silvery bit holding the shifter to the clamp in my picture above is the separate part I am referring to.
So you could ditch the matchmaker and hang the shifter off the reverb remote mount or leave it as it is.
I'd like to see what a non-MMX version looks like, i've never seen one.
Posted : 19/07/2012 3:45 pm
but wouldt I need to revert back to a regular clamp for my brakes?
Posted : 19/07/2012 4:43 pm
Yes if your currently matchmakered. Still an option though. I couldn't find a position I liked for the SRAM shifters and avid matchmakers so reverted to normal clamps. Now I'm using shimano and find the opposite, I can't put the shifter exactly where I want it!
Posted : 19/07/2012 4:45 pm
as notaspoon said.
I had a placement issue with my formula shimano combination and the hope xt matchmakers put them just where they need to be.
Posted : 19/07/2012 6:59 pm
