Had my Reverb bleed yesterday after it was losing air and sagging, guessing it is in need of major overhaul. It is a 2013 model if that makes a difference.
All help welcome.
Bleed won't fix sag in the post, it needs a service.
Best place to send and costs? Thanks for the help.
Depends where you are. I use TF Tuned for everything suspension and they can certainly do reverbs. Probably not the cheapest but i have never seen anything negative said about them, always generally high praise. Have an inkling you're up north...I think Eighteen Bikes service reverbs based on their instagram feed.
Is it definitely losing air? When it sags, does it pop back up, or stay sagged?
Loses air from 250 psi to 105 overnight, pump up slight say then works, hissing sound on depression of the lever.
