Reverb left or righ...
[Closed] Reverb left or right question.
[#7188083]
I'm looking to to order a reverb dropper for Mrs Floss's bike and left and right hand levers are of course available.
Question, is that with the button on top or slung below the bars.
Thanks in advance
F
Posted : 11/07/2015 6:16 pm
I just purchased a new reverb my first dropper and opted for a rh lever as can be put under bars on left side good for us 1x10 riders or if you're more modern and flush,, 1x11ers.
Posted : 11/07/2015 6:29 pm
Yes, a right reverb will be left lower mounted as hopeychondriact says
Posted : 11/07/2015 6:32 pm
Sorry for the hijack but what is best if you still have gear a front deraleur?
Posted : 11/07/2015 6:33 pm
Iwould always put it on the left because even if you have front gears you change them a lot less than rear gears so it is less in the way .
Posted : 11/07/2015 6:47 pm
Thanks for the info chaps, much appreciated.
Iride, I have a front mech and have tried both tucking the button under on the right but it was a long way inboard on the bars and meant I needed to move my whole hand in to press. I've now swapped it over onto the top left so I now only need to move my thumb up to press. All I can say is try it and see what you prefer.
Without a front shifter left and underneath must be the perfect position!
Posted : 11/07/2015 6:49 pm
 Olly
on top they seem very vulnerable to getting smacked. Its a hydraulic cylinder, so bending it will probably ruin it?
Ive got mine on the left hand side, very inboard. Need to have a smoother section of trail to unweight hand and press the button with a thumb stretch.
Posted : 11/07/2015 7:45 pm
Mine's on the right, underneath. Use my index finger but took a while to NOT get confused with the rear mech downshifter, fine now though.
Posted : 11/07/2015 8:22 pm
Mines in the standard on top position on the left.. Like the idea of moving it underneath using a right hand remote but I will probably just wait until it's an issue.
Posted : 11/07/2015 8:48 pm
I have a left one, upside down on right.
Posted : 11/07/2015 8:53 pm
Ok, it's not a problem for me as I have 1 x 10 , but we're about to order one my gf. It's hard to know what she'd like.
Posted : 11/07/2015 9:59 pm
RH, mounted under the bar on the left. Just seems the common sense way to do it (1x10).
Posted : 11/07/2015 10:15 pm
