Reverb leaking afte...
[Closed] Reverb leaking after hose change?
[#7612695]
So I changed my hose on my reverb, and its now leaking from the seat post end whenever I press the lever. I've used 2 new barbs (?) And its still doing it. What am I doing wrong?
Posted : 29/01/2016 4:17 pm
Anyone?
Posted : 29/01/2016 4:50 pm
Mine did that, recut the hose, made sure it was square with no burrs etc and screwed it all back together and it seemed to seal up properly.
Posted : 29/01/2016 4:52 pm
I've recut it etc so many times I've lost count now! I'm Really getting frustrated!
Posted : 29/01/2016 5:17 pm
Have you put the copper washer back on the barb? Or has it disappeared into the floor never to be seen again?
Posted : 29/01/2016 8:03 pm
Its sorted now. Although I have no idea which copper washer you are referring to?
Posted : 29/01/2016 8:13 pm
I have also never seen a copper washer.
Mine did this. Turns out I just needed to do it up even tighter after a number of recuts and rebleeds. Tricky as you can't see when it's seated cos of the protector bit.
Posted : 29/01/2016 8:37 pm
