Reverb hose fit in ...
[Closed] Reverb hose fit in camber frame?
[#6071854]
Has anyone tried to fit a reverb hose inside the holes that take the cable from the specialized seat post?
It looks very tight. Thanks Chris.
Posted : 28/03/2014 11:49 am
Hi Chris, as far as I'm aware from reading other posts on different forums, the cable guides on the old style Camber are too small for a Reverb (they are designed for the Specialized Command Post which is cable-actuated and thus has a slightly narrower cable run than hydraulics).
I'm not sure about the newer (2013+) model Cambers though. I'd also like to know about any potential workaround that people have managed to do because I'd like to stick a dropper post on my 2012 Camber at some point this year.
Posted : 28/03/2014 1:04 pm
I have a reverb on my 2011 camber, just using the dropper guide clips.
Posted : 28/03/2014 1:30 pm
You can drill out the stops carefully if you want to fit a Reverb . As hes been said it is designed to take a cable operated dropper .
Posted : 28/03/2014 2:31 pm
Are we talking about the cable clips that fo along the top tube? If so I can't see the issue.
Posted : 28/03/2014 5:48 pm
Its a 2013 camber expert and the dropper post cable goes inside the top tube, its carbon so i dont think i will be drilling.
Thanks all, so far.
Posted : 28/03/2014 7:32 pm
 J273
Its the same on the stumpys and enduros. I think alot of guys use a bit of sandpaper on say a drill bit to open the hole slightly to fit the hose. Dont actually use a drill - Just the bit with sandpaper wrapped round it to make the hole slightly bigger.
Edit: ^^^ Thats with the carbon frames.
Posted : 28/03/2014 7:44 pm
It's not the actual hole in the frame it's a stop inside it so no structural issues with enlarging ,a fine file or a dremel is safer than a drill though . Having said that the new Thomson dropper post is really smooth and totally free of play and IMO better than the reverb and would fit your frame without modification .
Posted : 28/03/2014 7:55 pm
Got a 2013 camber - alu frame though - and as above, opened the hole up.
From memory it's about 4.5mm as standard, and a reverb hose is 5.5mm
Used a hand reamer to give a nice clean finish. (Benefits of working in an engineering company.....)
Can't see how they will ever tell I've done it (without measuring) if I ever needed to warranty the frame.
Newer ones with the revised internal routing just uses guide ports/blanks which are plastic so much easier (and less scary!!) to do than the actual frame.
Posted : 28/03/2014 8:25 pm
