Reverb gone slow
[Closed] Reverb gone slow
[#3635257]
Anyone elses reverb gone exceedingly slow retuning to high setting ? Even with adjuster adjusted to fast speed.. and I mean really slow, like 50/60 seconds to return... was worse at minus 4 last night !
Any solutions or is it a Rerturn to base issue ?
Posted : 02/02/2012 10:43 am
Has it been back before Si?
Posted : 02/02/2012 10:48 am
Lube the shaft. It slides up and down through the seals, which are quite good, so there is a bit of friction.
Dont lube it with WD40 as that will remove the grease, use some oil.
Then try it.
Posted : 02/02/2012 10:51 am
Put some air in via the valve in the base, 250psi should lift you up alright.
Posted : 02/02/2012 11:13 am
Hi Matt, no its not been back before.
Posted : 02/02/2012 12:11 pm
The cold doesn't do them any good I imagine either.
Posted : 02/02/2012 12:15 pm
The cold wont change the air pressure or change the friction by any amount you would notice.
If it was cold enough to do that I reckon you would be dead.
If its got the right pressure in it, just lube it. Its not magic, its very simple inside.
Posted : 02/02/2012 12:28 pm
Mine was slow, not as slow as yours though. Did a bleed, now sorted.
Posted : 02/02/2012 12:34 pm
Cold shouldn't make any difference, otherwise air-sprung supension forks would suffer in the cold.
Posted : 02/02/2012 12:38 pm
We'll send it back for you Si, should get upgraded to newer spec and sorted out. Worth doing while in warranty
Posted : 02/02/2012 12:49 pm
mine went cold last winter, bled it again and its been perfect ever since.
Only takes sixty seconds - so long as you dont lose the screw! 😉
Posted : 02/02/2012 2:08 pm
Cheers Matt.. that would be a winner, dropped it off today (with rest of bike).
Posted : 02/02/2012 11:32 pm
and could do with doing as the plastic bit where hose goes into head is mangled.
Posted : 02/02/2012 11:33 pm
