My Reverb has suddenly started to go both up and down slowly. The only thing that could have caused a difference is me flying over the bars and the bike having a good bounce around after which the seat no longer pointed forward. I loosened clamp and re-aligned it but am wondering if this has caused the problem. I have tried slackening off the clamp completely and this makes no difference to Reverb speed.
How to return it to its previous rapid movement?
check the pressure. They try a bleed.
Clamp too tight?
Yep thischeck the pressure. They try a bleed.
Could be this. Dropper posts can be quite susceptible to being clamped too tight.boobs - Member
Clamp too tight?
IIRC the Reverb has a max torque setting of 6.7nM
EDIT - Ignore that, I missed the bit about undoing the clamp. 😳
Try a bleed first.
has the speed adjust twiddleyknob been moved?
Still does it with clamp completely slack
Re bleed
What M1llhouse said....could be something simple like that.
