My Reverb needs a full service. The dreaded inch of sag has become 2 inches (75mm dropper anyone). There is oil mixing with the air.
A quick look inside the lowers shows the foam washer looking decidedly second hand and a nick in one of the O-rings.
It is still functioning perfectly, but neither Lever nor Lever/Post bleeds are getting that travel back.
It is out of warranty and I bought it second hand so I don't want to spend a fortune on it. So who:
- offers the best Value for Money (cheep!)
- won't take one look at it and say "replace".
It doesn't have to be perfect, just needs to get through the winter.
Loco off here? Anywhere else?
Jason aka [url= http://www.reboundsuspension.co.uk/ ]http://www.reboundsuspension.co.uk/[/url] is pretty good.
He's in Horwich.
£72 inc. postage is pretty good, thanks.
Anyone know any LBS in West Yorks who fancy a go cheap?
Hi,
I've done a couple of these and both times it has been the Oil level inside the post. Both times resetting the IFP Height which you can get a tool @£6 or make your own as I did.
My experience is the above problem is common when the seat locks out lower than full extension.
If the seat moves down slowly when under pressure, I find this is common with the O ring on the lower seal head-which you get in a kit for about £7.
Nick
Saving this thread for future reference 🙂
This is the link you will need-don't go inside if you aren't competent,
http://forums.mtbr.com/all-mountain/rock-shox-reverb-ifp-bleed-procedure-785890.html
One of the link shows the inside of the seatpost.
Enjoy.
Thanks guys. I've seen that video.
Fashioning an IPF tool wouldn't be hard, but I don't have the post bleed kit (different from the regular bleed kit), much spare hydraulic fluid, any slick honey or rather ashamedly... a vice.
Whether it is worth getting all of them, rather than paying £72 is an interesting one.
Or fifty notes to an LBS might still be preferred...
