I have the standard and gradually changing a few things.
Next upgrade is to a reverb but fancy a stealth, can any owner tell me if the small hole in the bottom bracket is for the fitting of stealth. If so do you run the cable back up the seat post and across under the top tube. I can see the guides there already and hand for running a standard reverb.
What are the pros and cons between stealth or standard cable other than droopy Cable when the seat is down?
Posted : 18/07/2013 9:06 pm
