Reverb bleed woes
[Closed] Reverb bleed woes
[#7105515]
I have a bit of a problem reverb that I've just done a full rebuild of, which involved (for various reasons) removing the hose from the seatpost. The lever is a RH one mounted on the left so I have to flip it over to bleed it. When bled it all seems to work fine but when I flip the lever back over it immediately stops working. Does this sound like a sealing issue in the lever?
Posted : 02/06/2015 1:32 pm
Reverb hoses are pretty intolerant of the barb's not being 100% perfectly fitted.
I just rebuilt my seatpost and it started to slow down almost straight away.
So I made sure I properly tightened both barb's (I used a vice and the yellow blocks you get with Shimano brake to get a really solid grip on the hose)
I bled it again and it was spot on.
Posted : 02/06/2015 1:54 pm
Interesting, thanks. I'll give that a go.
Posted : 02/06/2015 3:30 pm
