Evening, How do you fit the axs controller to your bars if you already have a lock-out lever already in place? Any ideas? Where can it go?
Thanks,
Matt
Does it not have it's own clamp so can you not mount it alongside everything else?
Or is there no space? Can you move the other lockout lever?
Bookmarking, as I'd like to know the answer too.
One on top of the bars, one below.
Or if it doesn't work well like that, on top of the opposite side, as it should be a mirror function wise if nothing else.
Or it can't be too difficult to make a double mount and stack the remotes under the bar.
The AXS controller is just a switch so you don't need much space (any) for a lever swing, which should help with the ergonomics of multiple controllers.
Fit a Blip Box instead of the remote.
https://mbaction.com/best-bike-hacks-a-better-dropper-seatpost/
