[Closed] Reverb
[#7725769]
My 6 month old reverb has started to compress about 15mm any advise what to do? Is it an easy fix? Thanks in advance
Posted : 23/03/2016 9:44 pm
It's a known fault . Send it back for a warranty replacement or repair . It's nearly always a replacement though .
Posted : 23/03/2016 9:46 pm
When was the last time you topped up the air pressure?
Posted : 24/03/2016 9:16 am
The air pressure only affects the return speed, the 'not compressing when you sit on it' is the hydraulics' job.
Posted : 24/03/2016 9:36 am
I've got two that do this now. Send it back to whom?
Posted : 24/03/2016 9:38 am
Whoever you bought it from, assuming it's still in warranty. Mine went back to Chainreaction for the same thing and they're sending me a replacement.
Posted : 24/03/2016 11:33 am
Same here.
Took about two and a half weeks from the date it left me to the delivery of a new one. This was via Collect+ which isn't the speediest way of getting it back to them but it's free and the Co-Op is open late.
If you're lucky you might get a new one with revised internals in return.
Posted : 24/03/2016 11:56 am
otsdr - Member
Not necessarily true - mine had a slight drop, checked and found the pressure was down around 200, back up to 250 and it's fine again. I think a slight hydraulic problem will be more obvious of the pressure is off.
Posted : 24/03/2016 12:14 pm
