Revelation service
[Closed] Revelation service
[#6726577]
I serviced the lower legs of my revs and they are still a bit rubbsih.
Thinking the damper cartridge is lacking oil.
Anything to stop me just undoing damper top hex nut and pouring some oil in withour relaesing the circlip at the bottom etc...
Need a quickish fix to allow me to run them over Xmas..
J.
Posted : 24/12/2014 12:54 pm
It will be fine to just top up or replace the oil, just make sure the cartridge is in the fully open position when you put it back in!
Posted : 24/12/2014 2:47 pm
yep you can do that as quick fix.
Ideally you should give it a proper service replace the o rings etc as they as also deteriorate not the just the damping oil.
whats the problem you are having? Someone may be able to give to tips on how to fix it.
Posted : 24/12/2014 4:55 pm
