Revelation RLTi set...
[Closed] Revelation RLTi set up issues
[#3164895]
Have a set of 2011 RS Revelations 150mm RLTi Dual Air's. This is my third set of revs and I have the u-turn version on my hardtail. However, I have an issue with the RLTi's in that they suck down into their travel if the negative air pressure is even around 75% - 80% of the positive. I'm aware that increasing the negative air spring has this affect, however you usually have match or exceed the +'ve psi for the to happen.
I have lowered the forks from 150 to 140 but can't see how that would affect this. If +'ve and -'ve are equal then they suck down around 10 - 15 mm. Is this a characteristic of the RLTi's or do they need to go back for a warranty job ? My team u-turns sink down a couple of mm but nothing like these.
Other options are to return to 150mm and with them sitting down 10mm I achieve the 140mm that I'm after, or decrease -'ve until they sit at 140mm but this will surely affect small bump sensitivity ?
Any advice welcome ?
Posted : 20/09/2011 9:22 am
This doesnt help at all, but mine do exactly that as well
Posted : 20/09/2011 9:23 am
Balancing pos and neg air doesn't seem so important in the "blackbox" damped Revs, I know you had to get the old ones just right and sometimes I had to run more neg than pos to be happy with them.
Have you ridden the fork with less neg air in and were you unhappy with it?
Posted : 20/09/2011 9:30 am
No I've not ridden them with the -ve at the level that prevents them sinking. I'll give that a go. I've had them 10 psi lower and they were ok but again sinking into travel when off the bike.
Posted : 20/09/2011 9:41 am
I've noticed the same thing on mine, have they revised the size of the air chambers?
I've already done the piston reset, didn't fix it. Only thing I can think is that there is too much oil in the neg chamber or something.
Posted : 20/09/2011 9:47 am
I'm guessing it doesn't really matter where the balance point is ? Some sort of manual would have been useful. I could try to balance them with less -ve than +ve.
Posted : 20/09/2011 10:14 am
It depends if they're extended or compressed when you screw in the -ve air valve after a service. Think about it. The lower chamber is now sealed.
Posted : 20/09/2011 11:32 am
