Revelation forks &#...
[Closed] Revelation forks 'sucking down'?
[#7079453]
Not been out on the bike for a few weeks and noticed my revelation forks are sucking down to 30% sag without any weight on the bike. I can 'try' and extend them fully by hand but it feels like a vacuum is pulling them down again.
Any ideas what's up with them?
Thanks.
Posted : 20/05/2015 7:40 pm
If they're the Dual Air model, try dropping the pressure in the -ve air chamber.
Posted : 20/05/2015 7:42 pm
Sorry should have said, solo air.
Posted : 20/05/2015 7:43 pm
Anyone else had this?
Posted : 20/05/2015 10:16 pm
 Rich
Yes.
I undone the bolt at the bottom of the air leg and then released the air from the valve inside.
They haven't done it since.
Posted : 20/05/2015 10:29 pm
Best long term solution - strip them down and clean, then rebuild using oil not grease.
Posted : 20/05/2015 11:11 pm
 br
Yep, and a DIY lower leg service didn't solve the pull-down.
Spoke with Loco and he said it was to do with dirt in some valve. So sent them off for a full-service with them.
Fixed now and work fine.
Posted : 20/05/2015 11:34 pm
It's an air leak. A service might solve it, it might not.
Posted : 21/05/2015 3:12 am
Or a vacuum caused by the port blocking if it's the same as the other solo air ones I've seen do that. Lower service should check that part out.
Posted : 21/05/2015 3:13 am
I have some pikes that did the same thing just after I arrived in Spain. A mix of deflating, inflating, pushing and pulling left them back as they should be but they will be getting a service as soon as I'm back in the UK. Googling suggests a blocked transfer port so I hope a service will do the trick.
Posted : 21/05/2015 8:05 am
Theres a little dent (which might be a port) which can get blocked with grease, theres a thread on Pinkbike with pics.
Posted : 21/05/2015 9:16 am
 gee
Yep you need to do a lower leg service then pull the air side spring out and clean the little dent in the leg.
Posted : 21/05/2015 11:23 am
Do what Rich says first. If it happens again go down the service route.
Posted : 21/05/2015 11:30 am
 LoCo
It'll be a block negative transfer port (the 'dent')
Leaky seal, one of a number, service will sort.
If you remove the bolt on the air side the bottom of the air shaft has a valve core in that you can depress and extend the forks with, althouht if there's a leak it'll happen again fairly soon.
Thanks all, will have a go this evening.
Posted : 21/05/2015 1:38 pm
