I have a some revelations with MoCo damper which I want to upgrade. They have 35mm stanchions 29er with 150mm travel and serial number says they are 2017.
I have seen a cheap charger 1 damper for a Pike A1-A2 2014-2017 and I’m just wondering if it will fit?
Or what the part number for a charger 1 that will.
Any advice would be much appreciated!! Cheers
Forgot to mention they are boost spacing.
Have you tried putting your serial number in the rockshox trail head webpage? It should then tell you all available upgrades and the part numbers.
trailhead.rockshox.com/en/
Cheers for reply, I have tried that but it just gives the part number for the most current charger 2 and 2.1 dampers.
Seen a couple of charger 1 dampers going for cheap so thought I would give one a go if it fit.
Just get the Charger 2.1 damper - it’s not expensive if you shop around (Bike Discount is usually cheap) and it’s a better damper all round.
Jp
I thought the charger 1 dampers had a different thread to the newer forks but then some of them might have been compatible depending on boost / non-boost.
Cheers for the reply’s, maybe I’m looking for something that doesn’t exist!! Will look at getting a 2.1. Thanks again
€140 on Bike Discount if you're OK with Charger 2. €200 for Charger 2.1.
JP
Cheers for the heads up JP, is there much difference in performance between the two?
