Revelation Changes....
[Closed] Revelation Changes... year by year
[#6987412]
Think I may have settled (temporarily at least) on some Rockshox Revelations for my NS Surge build. Wanted to the Lyrics, but i thought save a little bit of cash and about half a kg! by getting U-Turn Revs first - I can always change later to Lyriks if I 'need' something burlier (I suspect I won't as I'm pushing and pushing and on fox 32s on the other bike and they still ride well!)
There seems to be any number of Revelations out there though going back years and years! Can anyone out there give a brief heads up if there's anything to look for? Has anything changed significantly over the years apart from the most recent black stanchioned models?
Posted : 09/04/2015 2:31 pm
Go for black box and dual flow rebound on the older ones...Job done.. 😉
Posted : 09/04/2015 2:35 pm
Sounds pretty conclusive! Got any lying around lol
Posted : 09/04/2015 4:18 pm
No but i got looked after good and proper on here on a absolutely mint pair of RTL-Ti's last week.
Great fork.
Posted : 09/04/2015 9:47 pm
You gotta presume they get better as the years go on in some way, like rockshox are not going to make their product worse
Posted : 09/04/2015 10:43 pm
 LoCo
140mm max till[b] 2010[/b].
Then 150mm max, RLT Ti and dual flow on dual air & uturn ( would probably avoid the uturns now though as getting a bit flackey)
[b]2012[/b] DNA compression damper and dual flow rebound (all models) still dual air but now Dual position travel adjust model too.
[b]2013[/b] DNA still but solo air fix travel.
[b]2014[/b] same.
[b]2015[/b] Black stantions, air token compatible top cap (retro fit kits for 2013&2014 available though) and rebound went to rapid recovery (very little different performance wise from dual flow.
Currently running some 2015 29er RCT3, with SKF wipers and different oil in. Have adjust air volume with Tokens & they are very good, so much so I'm not looking to replace them for a while now 😀
Posted : 10/04/2015 9:45 am
LoCo - Member
When was this golden age when they [i]weren't[/i] a bit flakey? 😆 Still like mine though.
I was pretty surprised when I rode the 2015s, I have the 2010 Teams and there's so little difference from 5 years evolution. Better adjustment.
Posted : 10/04/2015 10:09 am
 LoCo
When was this golden age when they weren't a bit flakey? Still like mine though.
😀 Very flakey now, majority that come in for service have issues, dual air or coil conversion is answer if chassis & dampers still in good condition.
It's of a mark of how good the RLT TIs were when they came out the small different between them & the 2015 model (out the box 😉 ) is.
Got on very well with my 2012 dual air RCT3 revs too.
Current ones are the best by a fair margin now though, with the tweaks I done 😀
Posted : 10/04/2015 10:18 am
Trust you to have secret oil Si... 😆
Just done the service on my Ti's Mr loco.Thanks for all the kit..
Posted : 10/04/2015 9:41 pm
Si.Just a quick one if you jump back on this thread.
If i chuck the RCT3 damper from my pikes that you did into my into the Ti's set at 140mm.
What's the oil volume.I know it was 140ml for the pikes.
Cheers..
Posted : 10/04/2015 10:20 pm
Aren't the RLt ti's just revelation teams?
Posted : 10/04/2015 10:45 pm
Loco if you do reappear did you catch my mail about the 32mm token kit sent earlier in the week? Id like one please if you have stock. Cheers 🙂
Posted : 10/04/2015 11:32 pm
I have a 2013 rev. Going back to Merlin as the travel adjust feature has stopped working.
Did not realise fork could be pimped with bottomless tokens.
Posted : 11/04/2015 6:59 am
