revelation air pres...
[Closed] revelation air pressures for fatties
[#1689413]
Ok, well for the heavier individual, the dual air race variety. Im following the guidelines for my weight (92-93kgs) and it says 135+ psi in each chamber.
Running 150psi in +ve and a bit less in -ve. Cant find any guidance on max pressure, but it stillfeels a bit soft to me, seems a lot of sag initially anyway.
Any ideas of what you can bump the pressures up to before they take off?
Posted : 09/06/2010 7:58 pm
Dunno if it works the same as the Pike, but I'm currently running 170+ve, 150-ve in mine and am about 107kg at the minute. Feels about right to me.
Posted : 09/06/2010 8:17 pm
ahh, excellent, il keep pumping a bit more then. I like it nice and stiff!
Posted : 09/06/2010 8:20 pm
As Tom- but with Revs. I'm a more than 'well-built' bloke. Happy running at the pressures suggested by Tom. I've run higher too. AFAIK, the forks won't explode/ die/ kill you. But I might be wrong!
Posted : 09/06/2010 8:39 pm
15st and i worried about putting 120psi in last night,felt a bit soft still, will experiment further now, first ime i've topped the air up since i got them 2 years ago though 😯
Posted : 09/06/2010 8:57 pm
