I have an S-works 2005 sumpjumper FSR120 and it currently has the septune shock. I know in 2006 they introduced the Brain in these , is there any way to retrofit a brain on my frame ? I only have the 2 lugs at the rear fro the Brake caliper and I believe for 2006 they added an extra lug on the frame to accomodate the brain. Has anyone retrofitted one of these ??
Thanks
anyone ?
i havent retrofitted but i did have an 05 epic with a brain and 05 fsr120 with septune. I always thought the brain needed too much of a hit to set off the shock and had it softened. Moving to the 120 was a big improvement and I wouldnt have wanted a brain on it if it was like the one i'd had. Having said that the later brains were i believe a big improvement over the early versions, with adjustable threshold so i'd be on the look out for one of them.
ive got a 05 120 expert which im doing up,no point fitting brain ! just fit a new fox rp23 like im gonna do. vader was bang on.
Yep that was the other option replacing the septune with an RP23 🙂
Maybe easier to go down that route
Cheers for the replies
