retro U.S.E sub ant...
[Closed] retro U.S.E sub antidive lefty type fork set up advise?
[#5761637]
hi
whats the maximum air pressure you can run?
im at 150 psi and they are still too plush (medium spring)
anyone know?
Posted : 10/12/2013 5:22 am
I seem to remember that one of their guys ran theirs at 210psi
Best bet would be to give them a call they are real friendly
Posted : 10/12/2013 9:17 am
Seem to remember having 180 psi with the med spring in mine, but this ^^^^ is your best bet 🙂
Posted : 10/12/2013 9:27 am
I think I've got mine at 180-200 or so. Though because of the anti-dive I found I could have it softer than other forks anyway.
Posted : 10/12/2013 9:45 am
if you pop this question up on retrobike somebody will probably have the manual / settings.
Posted : 10/12/2013 10:10 am
Used to run 200 psi in mine with a medium spring, and it was still very plush.
They still have some spares for the SUB, have you tried emailing to see if they have a heavy spring?
Posted : 10/12/2013 10:47 am
Are they any good? I always liked the look of em..
Posted : 10/12/2013 11:00 am
Found the instructions for mine - it's a Total Air cartridge, I've got the recommended air settings if you can tell me your weight in lbs.
I really like mine - the no-dive works well, and it's simple and tough. Plus the WTF factor is fun. I sold a few back when they were available, but really they were too expensive compared to more normal forks.
Posted : 10/12/2013 11:44 am
That's what put me off at the time, they look awesome though and I'm surprised the bigger company's didn't take up the idea
Posted : 10/12/2013 12:00 pm
hi guys thanks for all the responses.
ill stick some pics up when im finished my build as i have titanium titus frame which i cant identify also
ben im 154lbs what psi does your list suggest?
ill give use a ring tomorrow.
cheers 🙂
Posted : 10/12/2013 11:09 pm
Remind me tomorrow - I left the instructions on my desk at work 😉
Posted : 10/12/2013 11:34 pm
Okay, according to the chart you should be running 150psi, adjuster #2 for the rebound, and 5 or 6 turns out on the compression damping.
From memory, I found the chart settings a bit soft too, and went 10-20psi over them. There's a warning to never go over 200psi.
Posted : 11/12/2013 11:20 am
