Retro - Marzocchi X...
[Closed] Retro - Marzocchi X-Fly 2000 advice
[#4090521]
So I have a pair of these, new to me. I *think* I screwed the shock pump on too tight, and have screwed in the valve stems too far. Top of the valve stem is too far into the socket...
Before I muck it up proper, can I check that I can just unscrew them like any schrader valve inner...
Posted : 21/06/2012 7:15 pm
I think they're of an age where you'll need a cunning shock pump adaptor to put air into them.
Posted : 21/06/2012 7:19 pm
I have that cunning pump, it has odd adapter thingumy that I think I overtightened..the valves now leak out air with no resistance. This they did not when I was playing with pressure before said overtightening.
Posted : 21/06/2012 7:20 pm
In that case, you've got me. I'd just whip em apart, they're old marz, and will therefore be pretty simple things that you're unlikely to break.
Posted : 21/06/2012 7:22 pm
Post this on Retrobike. Someone on there will know for sure.
Posted : 21/06/2012 7:29 pm
