Replacing cables on...
[Closed] Replacing cables on a Canyon Exceed 9.9
[#8339931]
I am replacing the cables on my Canyon following crash repair (so no cables in place to follow)
They are internally routed
Front is sorted.
Rear - from the mech into the chainstay - is there a cable stop internally that i need to find with this cable? Doesn't make sense to have it lying freely in the frame - but I can see how to find this cable stop.
The manual does not help, and I can't find any info online.
Posted : 10/02/2017 8:30 pm
What have you got under the bb? Is there an access door? There is usually some guides there. My canyon has nothing (not an exceed) and I just ran a bit of foam hose up to stop it clacking around.
Posted : 10/02/2017 9:20 pm
Hi Nick
There is what MIGHT be an access door - it also holds guides for the rear mech if routed that way - with a single bolt. Having removed the bolt though it doesn't come out easily and i am loathe to force it....
Posted : 11/02/2017 7:45 pm
