Replacement RS pike...
[Closed] Replacement RS pike seals
[#7808813]
I've got a set of 2015 pikes and heard the 2016 have skf seals.
Does anyone know if the replacement seal kits are all skf now or have upgraded theirs with a RS kit?
I could just buy the green skf kit I suppose but makes more sense to stick with rockshock black ones.
Any help appreciated.
Posted : 04/05/2016 8:25 pm
Don't believe RS have changed part numbers so its hit and miss as to if you get new SKF wiper seals or not.
The green SKF seals have a lip IIRC so they don't sit flush like the standard rock shox ones.
Posted : 04/05/2016 9:31 pm
The two sets I fitted today didn't have a lip & fitted completely flush.
I'd personally rather use genuine seals, but they're on backorder at Fishers, so little choice.
It's also only the dust seals with the SKF & not the full kit, so you can't strip the charger damper etc & do a full service.
Posted : 04/05/2016 10:19 pm
Spoke to TF about pike seals a few days ago, they said they have found the new 2016 SKF seals sticky and are using low friction racing bros so something like that when they do a service.
I've been told the green low friction ones don't fit as above said.
Posted : 04/05/2016 10:23 pm
They must have updated them then as all the ones I have fitted in the past had a lip. Like the racing bros ones do too.
Posted : 04/05/2016 10:50 pm
