Replacement jockey ...
[Closed] Replacement jockey wheels for Shimano mechs - where?
[#945964]
Don't have to be Shimano
Posted : 12/10/2009 9:17 pm
crc are quite good apparently
Posted : 12/10/2009 9:18 pm
got some nice anodized ones on the bay all different colours too
Posted : 12/10/2009 9:35 pm
 nbt
I use Deore jockey wheels in my shimano mechs, £7 a pair from CRC
Posted : 13/10/2009 8:41 am
kcnc for pimp my jockey wheels.
Posted : 13/10/2009 8:42 am
KCNC jockey wheels are excellent, BUT they need to be modified to get the best from them. The top hat/dust cover pair that supports the bearing also allows a certain amount of axial float in the pulley, like the floating guide pulley on all Shimano derailleurs, however, this prevents the dust sheild from doing its job and preventing moisture/dirt from reaching the bearing seal. Trick is to lap/file/machine material from the tophat inner faces, so that the bearing is held correctly by the shoulders of the inner race, and no longer floats. This will allow the dust sheild to do it's thing and the bearing cannot spin on the tophat. Also, generously smear the return on the inside of the D/S with grease to keep water and dirt from contacting the seal.
You must also make sure that the bearing has been fitted centrally in the pulley (flush both sides). None of mine have been right "out of the box".
This has given me excellent bearing life both on and off road, and the elimination of the axial float in the guide pulley gives a really positive shift though it still waits for the ramps. However, as there is no "compensation" your indexing/alignment must always be spot on.
Posted : 13/10/2009 8:47 am
Alternatively.
Go to your LBS and say "Hello, i'd like some jockey wheels please." They'll sort you out. That is what they do.
Posted : 13/10/2009 9:36 am
Hmmm take a file to some overpriced alloy bling or fit something perfectly functional at 1/4 of the price.... 😉
Posted : 13/10/2009 9:58 am
I've a pair of little used XT (snapped the knuckle!)
Yours for £6 posted.
Were on my commuter, so road miles
Posted : 13/10/2009 11:35 am
ygm Andy
Posted : 13/10/2009 11:50 am
