Replacement freehub...
[Closed] Replacement freehub for deore hub?
[#210494]
woohoo, my first post on the *new* forum :o)
anyway; i need to replace the freehub on my girlfriend's bike. Deore freehubs seem a bit shonky and hard to find replacments of. Can I stick an LX or an XT straight on there?
Also, does anyone know if replacement ball bearings are easily obtainable?
Cheers,
Dave
Posted : 13/01/2009 11:25 am
yes to both. (though you may find that steel deore/lx level cassettes will wear little grooves in an alloy xt freehub and make it a bit harder to remove later on) most lbs's should have little packets of ball bearings for just that. For some reason i keep getting enough for 1 and a half hubs in the packet but that is fine for rear ones as i seem to wear out drive side ones fatster.
though with so many bargain hubs around on crc/woolyhatshop it might actually work out cheaper to buy a whole hub and strip it for parts. I did this just the other day with an older style lx hub. that way you get some spare cones and seals for your trouble too.
Posted : 13/01/2009 11:40 am
thanks :o)
time for some shopping!
Dave
Posted : 13/01/2009 11:58 am
