New ish reverb has gone spongey.
It was a replacement for a reverb that leaked at the lever, been services, had a new house, was bled repeatedly...
I though the newer one would be more reliable. I could get it serviced/ replaced under warranty and it will probably be fine. I've just lost the will to fix it again.
My mates told me not to get a reverb, they were right.
So once I've got it sorted, what to replace it with?
It's 30.9mm and 200mm drop.
Thanks.
Brand X Ascend XL
Brand X Ascend XL
+1, end of discussion.
Unless you're tight for stack height, in which case OneUp. I've only ever used Brand X droppers for the past 5or so years since sacking off my Reverbs. Never looked back, never had an issue. Currently 200mm versions on 3 bikes.
PNW Loam has further adjustment to the drop if you are inbetween sizes, and they are very reliable.
Thanks!
That's the same post I was recommended by my mate each time I've had to do a whole ride stood up 🙄
That’s the same post I was recommended by my mate each time I’ve had to do a whole ride stood up
Any cable one will work and they all work the same it's not like suspension where "quality" really matters....
Fox are a bit shit and expensive and fall apart.
Thomson are really well built BUT expensive and feel the same in use and you have to pay more than a brand X for a service.
Brand X are cheap, feel the same in use and dirt cheap and easy to service when they finally need one. The whole cartridge can be replaced for £30 or so .. and seal and keys are about a tenner... (its ridiculously easy to service as well)
The levers are a bit crap but useable but I eventually sprung for ZTTO ones..
