replacement disc qu...
[Closed] replacement disc query
[#2327464]
On my Hope mini disc's I want to do a disc swap
But hope discs are 145/165/185
Would using cheaper disc's 140/160/180mm be ok because they are only 2.5mm smaller in radius??
Any othere cheapskates tried smaller discs and were they ok
Posted : 31/12/2010 11:08 pm
will be fine
Posted : 31/12/2010 11:27 pm
ta for that
Posted : 02/01/2011 9:38 am
 cp
How close do your pads get to the outer edge of the disc at the moment? My avids are within a mm of the disc edge, so taking 2.5mm off the disc radius will mean the pad will overlap the edge and cayse it to wear with a step.
You could use a calliper adaptor for your proposed disc sizes, but that adds to the cost. There must be alternative rotors the right size which are cheap enough?
Posted : 02/01/2011 10:33 am
CP good point about the caliper adaptor but I do not have post mount brakes
I will have a good look at the pad position prior to replacing
Thanks
Posted : 02/01/2011 6:13 pm
