I have a set of these on the bike and think I've bent the right axle in a crash.
[img] &bgc=ffffff&fade_start=20%[/img]
Does anyone know if the replacement axle from superstar components will fit this model? They look visually identical but I've not got a nano to compare it to.
As long as it's the same pedal body, yep the axles are interchangable but there's different shapes of nano that have longer or shorter axles.
Hmm, looking at the platform dimensions in the specs it shows:
Superstar:
105x100x17mm LxWxD
Carbon Cycles:
94x95x17mm
So a difference in the pedal body albeit a small one. Reckon that's going to cause a problem?
A bump for the inebriated Friday evening crowd perhaps...
Hmm, e-mailed and heard back from Carbon Cycles they don't supply spare axles for these.
One last ask before I investigate other options but has anyone successfully used the axle from superstar in this model? I know I wont get an answer from SSC...
