Repairs to tears in...
[Closed] Repairs to tears in tyres
[#1371985]
How are you doing yours?
Got a new non UST Race King with a torn sidewall, and my mates got two brand new torn NN's
EDIT; UST Nobby Nics.
Posted : 01/03/2010 4:30 pm
 Pook
gaffered up the inside, superglued the out. Held for many more miles afterwards.
Posted : 01/03/2010 4:44 pm
Pooks solution sounds like the sort of thing I'd try. Anygood with a darning needle? Could give some extra mechanical reinforcement. Then Duck tape inside and superglue the tear.
Best of luck.
Posted : 01/03/2010 4:48 pm
For smallish tears up to maybe 10mm, roughen up the inside with emery, cut out a piece of old roadie tyre, and super-glue it on. I've seen long tears on non-UST tyres sown up with dental floss, although I've never tried it myself or know how long it lasts TBH.
Posted : 01/03/2010 5:28 pm
Try anything you feel happy riding down a rocking singletrack at speed with 😉
Posted : 01/03/2010 5:33 pm
I've used the gaffer / duct tape on the inside approach for small tears. Works ok as it spreads the load from the tube over the undamaged carcass.
Posted : 01/03/2010 5:34 pm
 br
Superglue for me, along with just a normal patch on the inside - done it with two 2.4 NN's, and they hold up well running tubeless.
Posted : 01/03/2010 5:36 pm
i tried using tape on the inside of a new tyre but kept having to replace it every few weeks as the tape ripped on stones/ roots.
recently have been trying to use a plastic shim on the inside, like the ones you get for mounting lights, and then holding it in place with some duck tape. not sure i would rely on it for a remote ride, but for trail centre use it has been holding up fine. saved what was an expensive tyre for me.
Posted : 01/03/2010 5:40 pm
Got a ProRace2 I can cut up.
Posted : 01/03/2010 5:44 pm
I had this recently, on a Conti Ultra Gatorskin that had been on for a week 😡 I've ummed and aahed about bodging it, but ultimately decided that my safety was worth the £24 for a new tyre. YMMV
Posted : 01/03/2010 7:21 pm
shove an inner tube patch on the inside of the carcass if it's a MTB tyre - should be OK as low pressure
not sure what'd hold a biggish cut in a road tyre but at least a patch on the inside is being pressed on and not pushed off the carcass
Nobby Nics are soo bloody fragile - I've cut a UST one twice in about 4 rides, the second being a flint that pretty much severed one of the centre knobs. I've patched it again & cut off the knob - we'll see (planning on using tubeless again)
Posted : 01/03/2010 8:42 pm
