Removing stuck oliv...
[Closed] Removing stuck olive from brake lever
 jfeb
[#1572982]
I have managed to break off the end of the hose, complete with olive, in a completely unused XT Dual Control lever/shifter. I re-used the hose and olive from an older brake lever and in trying to remove it the hose has snapped. I have heard of this happening to others (although my LBS has never seen it before!) Has anyone had this happen to them and had any success drilling the olive out? I have only a hand drill and can't imagine this working without damaging the threads in the lever.
Posted : 04/05/2010 4:25 pm
It is possible, but you obviously need to be careful not to damage the threads, did it to a Hayes brake last week, fair bit of hassle followed by the discovery of scored bore meaning it was scrap anyway.
Posted : 04/05/2010 10:00 pm
Find a wood screw and wind it carefully into it.And try pulling it out with pliers.
Posted : 04/05/2010 10:37 pm
 jfeb
Thanks chaps. A good tip with the screw too. I'll give that a go. Before I snapped the hose I had already tried pulling the lever while standing on the hose - God knows how much force will be needed to get the little blighter out.
Posted : 05/05/2010 7:51 pm
cocktail sticks are often used to spear olives.
HTH
Posted : 05/05/2010 9:18 pm
 jfeb
nicolaisam, I love you. I used a self-tapping screw. Took a few goes but result!
Spey Stout, 🙂
Posted : 08/05/2010 12:40 pm
No problem 🙂 🙂
Posted : 09/05/2010 6:56 pm
