Removing Straitline...
[Closed] Removing Straitline pedal bushings
[#3774618]
Hi all, after many strip/rebuilds of my Straitline pedals, I've finally given in to replacing the bushings. Having trawled the web, it looks like you need a special tool to remove - anyone bodged with a hammer/screwdriver/lump of cheese/etc?
Posted : 15/03/2012 10:04 am
I just set the pedal over a gap in a vice and knock it out with a screwdriver and a hammer! Doesn't matter if you ruin them as they are already shot. Just go steady working around the bushing and it should pop out. Simples
Posted : 15/03/2012 10:10 am
A screwdriver is all you need. If you can strip them down what makes you think you need additional tools?
Once you remove the 2 circlips you have access to all the parts by sliding them off the axle?
Im presuming you have the standard (De Facto?) Straitline pedals?
Posted : 15/03/2012 10:11 am
cool, will try that - don't have a vice, but will use a big socket or something.
Posted : 15/03/2012 10:13 am
@ creamegg - it's not replacing the axle bushes (rebuild kit), it's the inserted top-hat shape bushes that need replacing.
Yup, standard Straitlines (not AMP).
Posted : 15/03/2012 10:16 am
ah yeah ok im with you now
Posted : 15/03/2012 10:51 am
