Removing Squre tape...
[Closed] Removing Squre taper crank - help advice needed
[#843066]
I have a drive side crank stuck on. Weirdly the threaded bit you screw the adapter in to is larger than the crank extractor thread.
I cant really get any implements in between it and the bottom bracket as there is a DMR chain guide device that is in the way. Cant use say aball jpint splitter as cant get in there
This also prevents me applying tons of levarage with a crow bar as the guid plate is flexing not the crank.
I dont mind destroying itto get it off but need advice on how
Would a three legged puller work?
Best way to hack it off?
Posted : 05/09/2009 7:16 pm
I tried using the side of a drill bit to wear away the metal, and it worked but I knackered the drill.
I suppose if a three legged bearing puller didn't work you could try drilling lots of vertical holes around the square hole untill there was no metal left and it came off?
Posted : 05/09/2009 9:10 pm
Can you do a pic? Not sure what you mean by the bit you screw the adapter into...
Did you see how I removed my Raceface? By sawing through the axle. Didn't take long! But there is no way of getting the right force on a crank without "pulling" it off at the axle.
Posted : 05/09/2009 9:15 pm
Unscrew everything and ride it for a bit.
Posted : 05/09/2009 9:26 pm
 nuke
If you've removed the bolt, can't you just cycle around on it until it falls off? Thats what I use to do with stuck cranks I wasn't bothered destroying.
Posted : 05/09/2009 9:28 pm
3rd riding on it. Kills the crank, but what-ho.
Posted : 05/09/2009 9:30 pm
WD40, 3 in one, ride it with no crank bolt on until it falls off.
Or apply some judicious heat...
aternativelly just hacksaw through the spider etc. right down to the taper, inline with the axle, might be tricky if it's super close to the chain device though
Yup, that works. Equally, you might be able to just muller it off with a rubber mallet.
no i lack a camera at present but a crank remover first screws into the crank and then you ighten nut to remove.
this whole in pic below.
[img] http://marcus.bointon.com/uploads/cracked_crank.jp g" target="_blank">http://marcus.bointon.com/uploads/cracked_crank.jp g"/> [/img]
Was that the BB axle you sawed through?
Posted : 05/09/2009 9:32 pm
im taking one of atm using a drill bit...if u have a crank extractor tho u can screw a bolt into the bottom bracket (small bolt...maybe just place it thier i used some m6's before) and use the extractor to push against them.
Posted : 05/09/2009 9:40 pm
i just lost my temper with mine using a rubber mallet... the crank with the bike still attached went hurtling across my garage
Posted : 05/09/2009 9:43 pm
usatvyogurtman ...Dont get what you mean as the crank extractor wont screw into crank when I turn so not sure how that helps
EDIT: in danger of doing that so asked here.
Cant ride it as bike in bits and now just a frame with a drive side crank arm attached.
Posted : 05/09/2009 9:50 pm
seriously
Posted : 05/09/2009 9:54 pm
 ton
johnnie, why wont the extracter screw into the crak, are the threads nacked??
Posted : 05/09/2009 10:02 pm
threads perfect but bigger than a standard extractor (DRIVE SIDE ONLY)
dont know why bought the bike as is.
Posted : 05/09/2009 10:10 pm
 ton
22mm threads??
Posted : 05/09/2009 10:15 pm
no idea just bigger but only a little bit the standard size is only just too small.
Nice hols?
Posted : 05/09/2009 10:17 pm
 ton
very nice...ta
get the bike laid with the crank facing down.
then 2 people with hammer and drift/long screwdriver each and tap it off gently.
Posted : 05/09/2009 10:19 pm
tried a crowbar on my own without success
surely you know a more brutal technique that involves power tools?
Posted : 05/09/2009 10:21 pm
 ton
gentle is the way, like getting a tight pair of knickers of a lady... 😉
Posted : 05/09/2009 10:23 pm
I bow to your superior expertise on both matters 😀
Posted : 05/09/2009 10:29 pm
you have answered your own question. Use a puller, it will just pop of and do no damage if you are even mildly careful. done it many a time when ~I was too tight to buy an extractor. Maybe remove ring bolts for more space.
Posted : 05/09/2009 10:51 pm
ur problem with the extractor is that it wont screw into the crank arm?
Posted : 05/09/2009 10:59 pm
I had a new thread put on to a crank arm that was stuck. This involved getting a frame builder type bike shop to tap in a new, slightly larger than standard thread.
Might explain why your's is bigger than standard, but very weird if it's new - you didn't get it off ebay did you? A decent bike shop might be able to sort you out.
Hacksaw method is fun if the riding around boltless etc doesn't work.
Posted : 06/09/2009 1:00 am
High Path Engineering will have an adaptor you could use I think if it's only just a little bit bigger, if you've not already started drilling or sawing etc. They do a service where they rethread a crank with stripped threads so that it can be removed with a remover which is just a little bit bigger than normal.
Probably best to e-mail them.
http://highpath.net/index.html
Posted : 06/09/2009 5:59 pm
