Removing Reverb hos...
[Closed] Removing Reverb hose
[#10931786]
Hi everyone,
So my Reverb needs to go back under warranty and they only need the post itself, does the connector at the bottom of the post screw off?
I have removed one in the past using the connectamajig style set up but does anyone know how this comes off and if the post would need to be re-bled when re-installed?
I have the little red Rockshox barb which I usually thread in the end to stop any fluid coming out.
Thanks
[url= https://i.ibb.co/s6wSgXF/Screenshot-2019-11-26-at-10-12-43.pn g" target="_blank">https://i.ibb.co/s6wSgXF/Screenshot-2019-11-26-at-10-12-43.pn g"/> [/img][/url]
Posted : 26/11/2019 10:17 am
Right,from memory the black nut at the base of your Reverb unscrews. This will disconnect the hose from the post. Assuming you're leaving the lever on the bike? Don't drop the nut down the seattube :o)
And yes,will need re-bled when you refit it again.
Posted : 26/11/2019 10:51 am
