Removing remote loc...
[Closed] Removing remote lockout from Fox Forks
[#8146968]
Hi All
I have a new pair of new Fox Float 32 CTD Fit forks courtesy of CRC. The only downside is that they use a remote lever set up.
Is it possible to fit a standard fox twiddly knob instead of having to using the remote lockout and cable assembly?
Thanks
Ben
Posted : 05/11/2016 6:42 pm
You certainly can, presumably by reversing the procedure in these instructions:
http://www.ridefox.com/help.php?m=bike&id=620
If you do, I might be interested in buying the remote and top cap kit off you afterwards - have been put off by the price of the new kit so far.
Posted : 08/11/2016 7:45 am
As per above, I removed it from my fork and my shock.
Worth noting that if the bladder needs to be removed from the adjuster its not a straightforward item to bleed.
It's a shop job if you ask me.
I was present throughout the swap on mine and it was complicated.
Posted : 08/11/2016 9:32 am
