Removing Mono Mini ...
[Closed] Removing Mono Mini inboard piston
[#5736140]
Doing a full service on my mono minis. Have stripped down front lever and caliper. Bore cap is off and outboard piston is out. I can see the inboard piston but can't get it to come out. Is there a way of removing it without rebuilding and pressurising everything else?
Posted : 30/11/2013 6:36 pm
not without drilling it and hooking it out. if you have a compressor you can try blocking off all the holes and blowing the piston out
Posted : 30/11/2013 6:44 pm
 burt
Use a pump to blow it out via the bleed port. They pop out a treat
Posted : 30/11/2013 6:52 pm
No compressor at home and I'm re-suing the pistons. Been trying to ease it out but there's bugger all purchase / leverage. Might have to rebuild everything else and hold the other piston to force this one out.
Posted : 30/11/2013 6:57 pm
If I try a track pump, presumably I need to pop the other piston back in and jam it to force the pressure behind the inboard one?
Posted : 30/11/2013 6:58 pm
Got it, ****ing footery faff.....
Posted : 30/11/2013 7:30 pm
